はじめに
Sony Xperia Z2 (D6502, D6503, D6543)限定ーWi-Fiアンテナの交換方法です。
______________ ビデオマニュアル ______________
必要な工具と部品
ビデオの概要
バッテリーのフレックスケーブルの接続を外して、プラスネジを2本外します。
リチウムーポリマーバッテリーは3.8V、3200mAhです。
バッテリーのバーツ番号: LIS1543ERPC
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
11 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
3 件のコメント
Continu your learning
hi got my Xperia z replace the broken screen and I was told that the antenna is broke, wait over week to get fixed and still the antenna is so weak I couldn't load my Face Book
This guide seems to have been written just to promote the author’s own website. The advice is very poor, misleading and unhelpful.
(1) Removing the back panel will destroy it. All intending any repairs should have a replacement panel available before beginning.
(2) Replacing battery is as described.
(3) Author does not identify the wifi antenna correctly, nor supply advice on replacing it. Actually the wifi antenna is located at the lower right corner of the Xperia Z2 not upper left as shown. A connector wire runs along the edge in a groove and leads up to a connection on the motherboard. To replace wifi antenna unclip the connector, unscrew the mini circuit board, then reverse the steps with new board/connector.
