メインコンテンツにスキップ
Sony Xperia Z1 Compact Rear Camera Replacement
必要な工具と部品
  1. Sony Xperia Z1 Compact Rear Camera Replacement, Back Cover: 手順 1、 1の画像 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 2、 1の画像 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 3、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 3、 2の画像 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Rear Camera Replacement, Battery: 手順 4、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement, Battery: 手順 4、 2の画像 2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 5、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 5、 2の画像 2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 6、 1の画像 1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 7、 1の画像 1
    • Remove the battery from the device
  8. Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: 手順 8、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: 手順 8、 2の画像 2
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
  9. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 9、 3の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 9、 3の画像 2 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 9、 3の画像 3
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
  10. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 10、 1の画像 1
    • Remove the back frame.
  11. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 11、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 11、 2の画像 2
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
  12. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 12、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 12、 2の画像 2
    • Remove the external speaker.
  13. Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: 手順 13、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: 手順 13、 2の画像 2
    • Remove the square rubber gasket from the camera using the plastic spudger.
  14. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 14、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 14、 2の画像 2
    • Remove the black plastic corner still holding in the motherboard.
  15. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 15、 3の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 15、 3の画像 2 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 15、 3の画像 3
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
  16. Sony Xperia Z1 Compact Rear Camera Replacement: 手順 16、 3の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 16、 3の画像 2 Sony Xperia Z1 Compact Rear Camera Replacement: 手順 16、 3の画像 3
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
  17. Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: 手順 17、 2の画像 1 Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: 手順 17、 2の画像 2
    • Disconnect the camera from the motherboard using a spudger.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Kevin Bergstrom
メンバー登録日: 09/21/17
383 ポイント
3のガイドは作成済み
チーム
Washington State, Team S4-G1, Phelps-Hillen Fall 2017 Washington State, Team S4-G1, Phelps-Hillen Fall 2017人のメンバー
WSU-PHELPS-HILLEN-F17S4G1
6 メンバー
9のガイドは作成済み
コメント 1 件
The trouble is that the headphones jack and the monitor cables are unplugged when removing the motherboard and I do not think it is possible to plug them back in from the back side of the phone. I think the monitor needs to be removed for them to be plugged from the front.
natuk - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 13
今までの合計 896
