はじめに
A faulty charging port may lead to faulty charging misreads or your Sony Xperia Z1 not powering on. Replacing the charging port will aid in providing the phone with charging capabilities and will contribute to the overall better functioning of the phone.
必要な工具と部品
With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
Slowly slip the halberd spudger underneath the rest of the orange flex cable to carefully peel the adhesive portion away from the rest of the phone.
Use a T5 Torx screwdriver to remove the two screws on the long metal bracket along the left side of the phone.
Remove the metal cover with a pair of tweezers.
ある他の人がこのガイドを完成しました。
