メインコンテンツにスキップ
Sony Xperia Z1 - Password Removal, Firmware update with PC Companion
ビデオの概要
  1. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 1、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 1、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 1、 3の画像 3
  2. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 2、 2の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 2、 2の画像 2
    • Insert wisdom here.
  3. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 3、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 3、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 3、 3の画像 3
    • From here you can update your device firmware but it must be unlocked (device can't be in lock screen).
    • Start the new PC Companion function "Support Zone".
    • PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
  4. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 4、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 4、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 4、 3の画像 3
    • Your laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data
  5. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 5、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 5、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 5、 3の画像 3
    • After PC Companion prepared your laptop for the update, you must choose the model of your device.
    • The battery must be at last 80% charged.
    • Doesn't make a mistake in choosing the model.
  6. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 6、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 6、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 6、 3の画像 3
    • Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover.
    • Press and hold the volume down button and then insert the micro USB cable.
    • Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
  7. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 7、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 7、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 7、 3の画像 3
    • If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it.
    • S1Boot Fasboot drivers
    the link for fastboot drivers is not working for me
    Ali El Ouarzazi - 返信
  8. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 8、 3の画像 1 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 8、 3の画像 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: 手順 8、 3の画像 3
    • When PC Companion finished updating, disconnect the phone and switch it on.
    • Your device is with latest firmware, in factory state, without personal data and security.
    • Please SUBSCRIBE to my channel ツ
終わりに
19 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ZFix
メンバー登録日: 12/09/13
191,182 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
3 件のコメント
Thank you, this was really helpful.
DOWNLOAD AND UPDATE FIRMWARE SONY XPERIA XZ 601SO gofirmware
Jacky888 Jacky888 - 返信
which version is it? sony companion doesnt let you do it in latest. plz reply
DcKnown by Public - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 21,088
