はじめに
個人情報を削除する/しなくても、お持ちのデバイスを向上出荷時の初期化設定にリセットすることができます。この作業はデバイスが正しく稼働しない場合に必要になります。
必要な工具と部品
ビデオの概要
工場出荷時のデータ/ハードリセット
設定>バックアップ&リセット
データをバックアップするオプションがあります(この場合、Googleアカウントを登録している必要があります)
ハードリセットが終了したら、スマートフォンは再起動します。
上手くいきましたか?
I'm dumb and put my phone in water help
I am so stupid
I am dumb and put my phone in water help
I am so. Dumb
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
69 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
29 件のコメント
I will alrrady presss red bottan then he 3time vibration after no responses. Why I want to broken my pattern lock ...pls help
the same as yours
forget my paaword
i cant get into my menu
اصول صحیح مطالعه
Normally if you press for 5 sec the ON/OFF button and Volume + button , It will Soft reset
it worked :) thaks!
heraa -
It worked for Z1 Compact, thanks
Hi, I did as per your quote. My mobile screen got froze and did the ON/OFF button and Volume + . And when I switch it ON normally, it doesn’t turn ON. It just flashes Red LED light 3times. I have changed and inserted with NEW battery, but still it doesn’t turn ON.
Also I won’t loose any of my data, when I did the SOFT RESET.
ram -
Hey I have z1 when I touch settings operate speaking also how can I fix it ?
fanu malik - 返信
I've done all this several times but still no luck my son's phone has a number pin and we have no code for it and it's not doing a factory reset how can I fix it
Try what i suggested below :) Hope that helps
If you have signed into your google account on your phone, you should be able to sign into Android Device Manager: https://www.google.com/android/deviceman..., here you will be able to do a password removal and/or a factory reset in which everything on the phone is deleted.
Hope everything works now :)
Why is that, everytime i press ' erase everything' the 'Confirmation of PIN' will pop-up, but i dont have pin that register. Help! What to do?!
Also, the problem of my xperia z1 is that, when i open it it just stay good for 15secs. Then it says ' (etc. Not responding) then it gives 2 options, one is WAIT and the other is OK, then if i press ok and wait. The screen will turn black. Then it will restart automatically again and again.
refulgentel: I got exactly the same problem since yesterday, I tried to do the hard reset( with 3 different methods) but that's didnt worked
Fouond any solution ? Same here
kacmar -
Hi, I want to do the factory data reset my phone sony experia z1.
After click erase everything button, it request to confirm password?
but it pop up try again.
which password should i use?
the above procedures doesnt work at all. had to use Sony PC Companion software and select Repair Device to reset/erase the phone.
Not it will not work, because it will appear type pascode.
my sony z1 automatic shut down,software change,battery change,other than the board the whole changed same problem.
but main camera removing mobile ready
camera fixing,or camera changing same problm
eany solution?
Perfect Sr - 返信
When i put my card sim in he begin dowing stufs . Can i fix it pls help me.
i cant on my phone. Its keep on and off.. How to do hard reset
Try already but the red small button is not functioning..and totally not open..but if I charge is OK..
Roda Ledesma Dumayag - 返信
I try already to preS's that red small button but no responce..totally shutdown if I charge mobile is OK..but not open..tnx
