メインコンテンツにスキップ
Sony Xperia Z Loud Speaker Replacement
必要な工具と部品
  1. Sony Xperia Z Loud Speaker Replacement, Battery: 手順 1、 3の画像 1 Sony Xperia Z Loud Speaker Replacement, Battery: 手順 1、 3の画像 2 Sony Xperia Z Loud Speaker Replacement, Battery: 手順 1、 3の画像 3
    • Turn hair dryer to medium heat.
    • Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
    • Circulate the dryer for a full minute to soften the adhesive binding the phone together.
  2. Sony Xperia Z Loud Speaker Replacement: 手順 2、 1の画像 1
    • Once the adhesive is loosened, stick the suction cup to the top-center of the back of your phone and gently pull back.
    • Gently pull back just enough to create a small gap.
  3. Sony Xperia Z Loud Speaker Replacement: 手順 3、 2の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 3、 2の画像 2
    • Once you've opened a small space with the back cover, stick the plastic opening tool into the seam of the phone.
    • Move the tool along the seam to loosen the adhesive.
  4. Sony Xperia Z Loud Speaker Replacement: 手順 4、 1の画像 1
    • Caution: Pulling too vigorously or quickly on the suction cup could snap the back of the phone.
    • Once the adhesive has been adequately loosened, pull back slowly on the suction cup to remove the back panel of the phone.
    • The remaining adhesive should be strong enough to hold the phone together tightly upon reassembly. However, once opened the water resistance of your phone has been compromised.
  5. Sony Xperia Z Loud Speaker Replacement: 手順 5、 3の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 5、 3の画像 2 Sony Xperia Z Loud Speaker Replacement: 手順 5、 3の画像 3
    • Now that the back is removed, the battery is visible. You now have access to the battery and its connecting components.
    • With the plastic opening tool, gently remove the connector from the motherboard.
    • Use your fingers to peel the rest of the adhesive away from the phone.
  6. Sony Xperia Z Loud Speaker Replacement: 手順 6、 3の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 6、 3の画像 2 Sony Xperia Z Loud Speaker Replacement: 手順 6、 3の画像 3
    • With the plastic opening tool, carefully peel the white adhesive tape up from the bottom of the battery.
    • Use your fingers to peel back the rest of the adhesive tape away from the battery.
  7. Sony Xperia Z Loud Speaker Replacement: 手順 7、 3の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 7、 3の画像 2 Sony Xperia Z Loud Speaker Replacement: 手順 7、 3の画像 3
    • Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
    • Flex cables run vertically down the phone underneath the battery and can be damaged easily. Make sure to only place the spudger in the indicated area.
    • Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
  8. Sony Xperia Z Loud Speaker Replacement, Loud Speaker: 手順 8、 3の画像 1 Sony Xperia Z Loud Speaker Replacement, Loud Speaker: 手順 8、 3の画像 2 Sony Xperia Z Loud Speaker Replacement, Loud Speaker: 手順 8、 3の画像 3
    • The grey spacer is located in the bottom right corner of your phone, next to the vibrate motor.
    • Remove the grey spacer by gently prying it up from the right side with the spudger.
  9. Sony Xperia Z Loud Speaker Replacement: 手順 9、 2の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 9、 2の画像 2
    • Disconnect the vibrate motor flux cable by using the spudger to gently pop it up.
  10. Sony Xperia Z Loud Speaker Replacement: 手順 10、 1の画像 1
    • Remove the single 3 mm screw, set next to the vibrate motor, using a Philips #000 screw driver.
  11. Sony Xperia Z Loud Speaker Replacement: 手順 11、 2の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 11、 2の画像 2
    • Use the spudger to firmly pry up the plastic housing holding the vibrate motor and loud speaker.
    • Be careful not to pull the plastic housing out right away. The antenna circuit board is still connected to the main body and the antenna could be damaged if pulled on.
    • Start on the left and slowly move to the right prying up the adhesive and clips holding the plastic unit down.
  12. Sony Xperia Z Loud Speaker Replacement: 手順 12、 3の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 12、 3の画像 2 Sony Xperia Z Loud Speaker Replacement: 手順 12、 3の画像 3
    • Once the plastic housing has been removed from the main phone body flip it over to expose the antenna circuit board.
    • Use the plastic opening tool to remove the antenna circuit board from the plastic housing. This component is held in place with plastic clips and not adhesive.
    • Simply place the safe open pry tool next to the indicated clip and press on it lightly. The antenna board should pop free.
  13. Sony Xperia Z Loud Speaker Replacement: 手順 13、 3の画像 1 Sony Xperia Z Loud Speaker Replacement: 手順 13、 3の画像 2 Sony Xperia Z Loud Speaker Replacement: 手順 13、 3の画像 3
    • You now have access to the loud speaker. The loud speaker is the large square metallic object.
    • To remove the loudspeaker, use the wedge end of the plastic opening tool.
    • Place it underneath the top of the loud speaker and gently pry up to loosen the adhesive underneath.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Larsson Johnson
メンバー登録日: 02/03/14
2,333 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-7, Amido Winter 2014 Cal Poly, Team 2-7, Amido Winter 2014人のメンバー
CPSU-AMIDO-W14S2G7
4 メンバー
25のガイドは作成済み
コメント 1 件
Great guide just one thing you do not need to remove the battery to change de speeker, i had a hard time loosing it up and i decided to do the process without touching the battery with no problem.
ale - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 23
今までの合計 40,214
