メインコンテンツにスキップ
Sony Xperia XZ2 Front Camera Replacement
必要な工具と部品
  1. Sony Xperia XZ2 Front Camera Replacement, LCD Screen: 手順 1、 3の画像 1 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: 手順 1、 3の画像 2 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: 手順 1、 3の画像 3
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 Front Camera Replacement: 手順 2、 3の画像 1 Sony Xperia XZ2 Front Camera Replacement: 手順 2、 3の画像 2 Sony Xperia XZ2 Front Camera Replacement: 手順 2、 3の画像 3
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 Front Camera Replacement: 手順 3、 2の画像 1 Sony Xperia XZ2 Front Camera Replacement: 手順 3、 2の画像 2
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 Front Camera Replacement: 手順 4、 1の画像 1
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 Front Camera Replacement: 手順 5、 1の画像 1
    • Gently remove the connector by using a spudger to pop it off.
  6. Sony Xperia XZ2 Front Camera Replacement, Front Camera: 手順 6、 1の画像 1
    • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
    • Remove the one 3 mm Phillips #00 screws.
    • Remove the two 1mm Phillips #00 screws.
    • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
  7. Sony Xperia XZ2 Front Camera Replacement: 手順 7、 1の画像 1
    • Lift the metal screen shield out of the phone.
  8. Sony Xperia XZ2 Front Camera Replacement: 手順 8、 3の画像 1 Sony Xperia XZ2 Front Camera Replacement: 手順 8、 3の画像 2 Sony Xperia XZ2 Front Camera Replacement: 手順 8、 3の画像 3
    • Use the spudger to pop off the plastic protector.
  9. Sony Xperia XZ2 Front Camera Replacement: 手順 9、 1の画像 1
    • Gently pry up the battery flex connector using the spudger.
終わりに
作成者
1人の作成者と共同作成されました。
Chloe
メンバー登録日: 01/24/19
214 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019人のメンバー
CPSU-WHITE-W19S19G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 966
