メインコンテンツにスキップ
Sony Xperia XA2 Ultra Headphone Jack Replacement
必要な工具と部品
  1. Sony Xperia XA2 Ultra Headphone Jack Replacement, Rear Cover: 手順 1、 2の画像 1 Sony Xperia XA2 Ultra Headphone Jack Replacement, Rear Cover: 手順 1、 2の画像 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 2、 1の画像 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 3、 2の画像 1 Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 3、 2の画像 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 4、 2の画像 1 Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 4、 2の画像 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 5、 2の画像 1 Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 5、 2の画像 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 6、 1の画像 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Headphone Jack Replacement, Motherboard Bracket: 手順 7、 2の画像 1 Sony Xperia XA2 Ultra Headphone Jack Replacement, Motherboard Bracket: 手順 7、 2の画像 2
    • Remove the six 3 mm Phillips #000 screws.
  8. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 8、 1の画像 1
    • Remove the motherboard bracket with an iFixit opening tool.
  9. Sony Xperia XA2 Ultra Headphone Jack Replacement, Headphone Jack: 手順 9、 1の画像 1
    • Remove the single 3 mm screw using a Phillips #000 screwdriver.
  10. Sony Xperia XA2 Ultra Headphone Jack Replacement: 手順 10、 1の画像 1
    • Use the Jimmy to pry and remove the headphone jack.
終わりに
作成者
3人の作成者と共同で作成されました。
Alyssa Bayles
メンバー登録日: 09/27/22
819 ポイント
8のガイドは作成済み
チーム
Utah Tech University, Team 1-1, Randazzo Fall 2023 Utah Tech University, Team 1-1, Randazzo Fall 2023人のメンバー
UTAHTECH-RANDAZZO-F23S1G1
1 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 97
