はじめに
This guide will show you how to remove the motherboard from your Sony Xperia XA1 Ultra. The motherboard may need to be replaced if basic functions of the phone no longer run. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. Additonally, a T5 screwdriver is needed to remove screws while a spudger is needed to disconnect parts of the phone.
必要な工具と部品
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
この手順で使用する道具:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Insert your iFixit Opening Tool underneath the front camera and gently lift up.
Remove the front camera by lifting the front camera up with your hands.
Insert your iFixit Opening Tool between the back camera and the motherboard and gently lift up.
Lift up with the iFixit Opening Tool until the back camera is removed from the device.
2 の人々がこのガイドを完成させました。
3 件のコメント
yeah. Where??
