メインコンテンツにスキップ
Sony Xperia XA1 Ultra Headphone Jack Replacement
必要な工具と部品
  1. Sony Xperia XA1 Ultra Headphone Jack Replacement, Back Assembly: 手順 1、 2の画像 1 Sony Xperia XA1 Ultra Headphone Jack Replacement, Back Assembly: 手順 1、 2の画像 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 2、 1の画像 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 3、 1の画像 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 5、 1の画像 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 6、 1の画像 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Headphone Jack Replacement, Antenna Module: 手順 7、 2の画像 1 Sony Xperia XA1 Ultra Headphone Jack Replacement, Antenna Module: 手順 7、 2の画像 2
    • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
  8. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 8、 2の画像 1 Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 8、 2の画像 2
    • Insert your iFixit Opening Tool underneath the antenna module.
    • Lift up gently with the iFixit Opening Tool to remove the antenna module.
    • The antenna module may be difficult to remove.
  9. Sony Xperia XA1 Ultra Headphone Jack Replacement, Front Camera: 手順 9、 2の画像 1 Sony Xperia XA1 Ultra Headphone Jack Replacement, Front Camera: 手順 9、 2の画像 2
    • Insert your iFixit Opening Tool underneath the front camera and gently lift up.
    • Remove the front camera by lifting the front camera up with your hands.
  10. Sony Xperia XA1 Ultra Headphone Jack Replacement, Headphone Jack: 手順 10、 2の画像 1 Sony Xperia XA1 Ultra Headphone Jack Replacement, Headphone Jack: 手順 10、 2の画像 2
    • Remove the 4mm T5 screw connecting the headphone jack to the panel.
  11. Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 11、 2の画像 1 Sony Xperia XA1 Ultra Headphone Jack Replacement: 手順 11、 2の画像 2
    • Use your iFixit Opening Tool to lift and disconnect the headphone jack connector piece.
    • The small black piece connected to the headphone jack that is holding the single screw in place has broken off in the device shown.
終わりに
作成者
4人の作成者と共同で作成されました。
Jacob Jung
メンバー登録日: 04/18/18
1,429 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team S16-G3, Livingston Spring 2018 Cal Poly, Team S16-G3, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G3
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 626
