はじめに
I will teach the guide reader how to access this piece and to replace it, it must be purchased.
  1. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module.
    • Use the plastic opening tool to remove the loud speaker module.
  5. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Use the plastic opening tool to detach the ribbon running across the battery. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  7. Unhook the 2 connections between the harness and phone shell. Using the plastic opening tool, pry the harness up and remove it. There is an adhesive on the bottom half of the battery harness.
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  8. The final step is taking the entire harness off of the phone.
    • The final step is taking the entire harness off of the phone.
  9. Use the Phillips #00 to remove the 3 5mm screws. Lift the plastic cover off. Use the plastic opening tool to pry the motherboard out of the phone shell.
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  10. Use the plastic opening tool to detach the ear piece speaker.
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
  11. Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
まとめ
ある他の人がこのガイドを完成しました。
Adam Giniger
メンバー登録日: 2014年09月22日
1,235 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014人のメンバー
USFT-BROWN-F14S4G4
3 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 419
