はじめに
This guide shows how to open the phone and gain access to the headphone jack. It may either be pulled out and replaced, or simply readjusted in order to function.
必要な工具と部品
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to detach the ribbon running across the battery.
Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
Use the Phillips #00 to remove the 3 5mm screws.
Lift the plastic cover off.
Use the plastic opening tool to pry the motherboard out of the phone shell.
Use the plastic opening tool to detach the headphone jack from the motherboard.
Remove the motherboard and slide the headphone jack out of its slot.
ある他の人がこのガイドを完成しました。
