メインコンテンツにスキップ
Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement
必要な工具と部品
  1. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Rear Case: 手順 1、 1の画像 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 手順 2、 1の画像 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing the internal cover: 手順 3、 1の画像 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 手順 4、 2の画像 1 Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing Chip: 手順 5、 1の画像 1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 手順 6、 1の画像 1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Remove back facing camera: 手順 7、 1の画像 1
    • Then using the tweezer, carefully remove the back facing camera component.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Christina Wojaczyk
メンバー登録日: 09/26/14
1,450 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 13-3, Staggers Fall 2014 USF Tampa, Team 13-3, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G3
3 メンバー
7のガイドは作成済み
2 件のコメント
Hlo hi sir Sony back cam of Sony Xperia t2 ultra
sai kiran - 返信
Hi, Sir T2 Ultra dual Camera shows error - Unfortunately, Camera has stopped working. pls help . Thank yo
Alan Mathew - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 4,146
