メインコンテンツにスキップ
Sony Xperia M4 Aqua Rear Camera Replacement
必要な工具と部品
  1. Sony Xperia M4 Aqua Rear Camera Replacement, Back Cover: 手順 1、 1の画像 1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 2、 1の画像 1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 3、 2の画像 1 Sony Xperia M4 Aqua Rear Camera Replacement: 手順 3、 2の画像 2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 4、 1の画像 1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Rear Camera Replacement, Battery: 手順 5、 1の画像 1
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 6、 1の画像 1
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 7、 1の画像 1
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 8、 1の画像 1
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
  9. Sony Xperia M4 Aqua Rear Camera Replacement, Rear Camera: 手順 9、 1の画像 1
    • Remove the four hex head 3mm screws at each corner of the motherboard with a screwdriver.
  10. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 10、 2の画像 1 Sony Xperia M4 Aqua Rear Camera Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove three pieces of the securing bracket using tweezers
  11. Sony Xperia M4 Aqua Rear Camera Replacement: 手順 11、 2の画像 1 Sony Xperia M4 Aqua Rear Camera Replacement: 手順 11、 2の画像 2
    • Detach the rear camera connector from the front of the motherboard.
    • Remove the rear camera with your fingers or tweezers.
終わりに
5 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Sarah Wetzler
メンバー登録日: 02/10/16
487 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016人のメンバー
USFT-LACY-S16S4G5
3 メンバー
8のガイドは作成済み
2 件のコメント
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - 返信
That's the front camera. You have the front and rear camera mixed up!
mivanchev - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 3,525
