はじめに
This guide will take you step by step through the process of replacing your Sony Xperia L2 screen. This guide will help those who have a broken or unresponsive screen to extend the life of your phone.
  1. Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Use the plastic opening tool to pry the back case of the phone off.
    • Use the plastic opening tool to pry the back case of the phone off.
      • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Unclip circuit connectors from phone to motherboard.
    • Use blue plastic opening tool to pry off the motherboard.
    • Microwave the iOpener for 30 seconds.
    • Place the iOpener on the phone screen for 90 seconds to loosen the adhesive.
    • Use the suction tool and a pick to remove the screen from the phone.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    • Unhook the screen sensor from the phone to detach the screen from the device.
まとめ
Carrie Schmitt
メンバー登録日: 2018年09月10日
199 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team S2-G6, Bedsole Fall 2018 University of Alabama, Team S2-G6, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S2G6
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 39
今までの合計 70
