メインコンテンツにスキップ
Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement
必要な工具と部品
ビデオの概要
  1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 手順 1、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 手順 1、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 手順 1、 3の画像 3
    • Switch-off the phone.
    • Remove the battery.
  2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 2、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 2、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 2、 3の画像 3
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 3、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 3、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 3、 3の画像 3
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 4、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 4、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 4、 3の画像 3
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 5、 2の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 5、 2の画像 2
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 6、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 6、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 6、 3の画像 3
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 7、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 7、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 7、 3の画像 3
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 8、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 8、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 8、 3の画像 3
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the touchscreen from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 9、 3の画像 1 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 9、 3の画像 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 9、 3の画像 3
    • Install the new LCD into the frame and put adhesive tape.
    • Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 手順 10、 1の画像 1
終わりに
ある他の人がこのガイドを完成しました。
ZFix
メンバー登録日: 12/09/13
191,308 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,533のガイドは作成済み
2 件のコメント
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Yogendra Singh - 返信
Jo PCB main hota hai
Yogendra Singh - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 4,974
