必要な工具と部品
Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
Remove cover
Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
Locate the volume module.
Remove both screws using the Philips screwdriver.
Once both screws are removed grab the tweezers.
Then lift up on the module.
Find the electrical tape connecting the module to the motherboard
Carefully pull out the electrical tape horizontally and remove the volume module from the device.
ある他の人がこのガイドを完成しました。
