はじめに
In this manual we will show you how to do soft, hard (factory) reset and how to change firmware in case of forgotten Password, PIN, Pattern lock.
If you forgot your password and you can't log in your tablet with your Google account or backup PIN, then you must do factory reset.
This procedure will erase all your personal data.
ビデオの概要
Search and download Sony PC Companion or use the link below.
Switch off the tablet. If you can't do this, press and hold for more time the power on button.
Press and hold the volume down button until you connect the micro USB cable.
When the PC recognized the device, PC companion will download the latest firmware version and will upload it to your tablet.
If your PC can't recognize your tablet, you must install drivers for it. Search in the internet for "S1Boot Fastboot" drivers, or download the drivers from the link below.
10 の人々がこのガイドを完成させました。
2 件のコメント
How to remove a password, you need a password to do soo ....
There is a known problem with Sony tabs. If you use a locking code in which two zeros follow each other numerically . You lock yourself out, no version works ! Get the one with two zeros “00”, nor the one with “0” functioned.
If u not create a Sony-account and 2015 u do not need an alternative email address for your Google account. You can chuck away your Tab. Mine has been on the shelf since 5 years
