メインコンテンツにスキップ
Sony XAV-AX100 Display Board Replacement
必要な工具と部品
  1. Sony XAV-AX100 Display Board Replacement, USB Cable: 手順 1、 3の画像 1 Sony XAV-AX100 Display Board Replacement, USB Cable: 手順 1、 3の画像 2 Sony XAV-AX100 Display Board Replacement, USB Cable: 手順 1、 3の画像 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Board Replacement: 手順 2、 2の画像 1 Sony XAV-AX100 Display Board Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Board Replacement: 手順 3、 1の画像 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Board Replacement: 手順 4、 1の画像 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Board Replacement: 手順 5、 3の画像 1 Sony XAV-AX100 Display Board Replacement: 手順 5、 3の画像 2 Sony XAV-AX100 Display Board Replacement: 手順 5、 3の画像 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Display Board Replacement, Motherboard: 手順 6、 2の画像 1 Sony XAV-AX100 Display Board Replacement, Motherboard: 手順 6、 2の画像 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Board Replacement: 手順 7、 3の画像 1 Sony XAV-AX100 Display Board Replacement: 手順 7、 3の画像 2 Sony XAV-AX100 Display Board Replacement: 手順 7、 3の画像 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Board Replacement, Display: 手順 8、 1の画像 1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Board Replacement: 手順 9、 2の画像 1 Sony XAV-AX100 Display Board Replacement: 手順 9、 2の画像 2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Display Board Replacement, Display Board: 手順 10、 3の画像 1 Sony XAV-AX100 Display Board Replacement, Display Board: 手順 10、 3の画像 2 Sony XAV-AX100 Display Board Replacement, Display Board: 手順 10、 3の画像 3
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Display Board Replacement: 手順 11、 1の画像 1
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Display Board Replacement: 手順 12、 1の画像 1
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Display Board Replacement: 手順 13、 1の画像 1
    • Use a plastic opening tool to remove the display board from the radio.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Abdulaziz Redha
メンバー登録日: 02/22/18
741 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018人のメンバー
USFT-CAGLE-S18S1G5
2 メンバー
5のガイドは作成済み
コメント 1 件
Where can I purchase the touch panel glass screen?
Steven olivarez - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 1,707
