メインコンテンツにスキップ
Sony Walkman WM-AF48 Film Revolver Band Replacement
必要な工具と部品
  1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Getting started: 手順 1、 1の画像 1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: 手順 2、 3の画像 1 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: 手順 2、 3の画像 2 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: 手順 2、 3の画像 3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Film Revolver Band Replacement, Replace the band: 手順 3、 1の画像 1
    • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
    Would be useful to see the path of the band around these parts.
    Rus Woodward - 返信
  4. Sony Walkman WM-AF48 Film Revolver Band Replacement, Belt track: 手順 4、 1の画像 1
    • This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • I think you can rely on the same arrangement in other Walkman's
    I'm looking at a Sony WM-FX195 and the arrangement appears to be totally different. There's a wheel on the left (the same) but on the right there's only the motor. The right hand wheel is not present and the belt is very loose.
    jookieapc - 返信
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Wilson Riforgiat
メンバー登録日: 09/11/14
924 ポイント
4のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014人のメンバー
USFSM-STEWART-F14S1G4
4 メンバー
19のガイドは作成済み
3 件のコメント
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - 返信
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - 返信
Helped. Wanted an idea of how to open, before breaking it!
Troyf - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 31
過去 30 日: 105
今までの合計 17,304
