メインコンテンツにスキップ
Sony Walkman NWZ-E438 Device Circuit Board Replacement
必要な工具と部品
  1. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Disassembling Sony Walkman NWZ-E438: 手順 1、 1の画像 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 手順 2、 1の画像 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: 手順 3、 3の画像 1 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: 手順 3、 3の画像 2 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: 手順 3、 3の画像 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 手順 4、 2の画像 1 Sony Walkman NWZ-E438 Device Circuit Board Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 手順 5、 1の画像 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 手順 6、 1の画像 1
    • Carefully remove the circuit board from the device.
終わりに
For reassembling your device, follow the instructions in reverse.
作成者
8人の作成者と共同で作成されました。
Cheryl Zinn
メンバー登録日: 10/08/15
525 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-5, Plummer Fall 2015 Eastern Washington University, Team 2-5, Plummer Fall 2015人のメンバー
EWU-PLUMMER-F15S2G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 543
