メインコンテンツにスキップ
Sony Walkman A-45 Battery Replacement
必要な工具と部品
  1. Sony Walkman A-45 Battery Replacement, Battery Replacement: 手順 1、 1の画像 1
    • Turn on your Walkman and allow the battery to discharge below 5% before starting any repairs, as a charged Lithium Battery can be dangerous if accidentally punctured.
    • Turn off the device.
  2. Sony Walkman A-45 Battery Replacement: 手順 2、 3の画像 1 Sony Walkman A-45 Battery Replacement: 手順 2、 3の画像 2 Sony Walkman A-45 Battery Replacement: 手順 2、 3の画像 3
    • Insert a Jimmy into the thin gap between the shell and the side of the top cover, along the edge of one of the panels.
    • Pry up on the top cover to release it from the adhesive.
    • Once the adhesive doesn't stick from one edge, the rest disconnects easily. It will take a couple tries.
  3. Sony Walkman A-45 Battery Replacement: 手順 3、 3の画像 1 Sony Walkman A-45 Battery Replacement: 手順 3、 3の画像 2 Sony Walkman A-45 Battery Replacement: 手順 3、 3の画像 3
    • Insert a Jimmy into the thin gap between the shell and the side of the bottom cover, along the edge of one of the panels.
    • Pry up on the bottom cover to release it from the adhesive.
  4. Sony Walkman A-45 Battery Replacement: 手順 4、 2の画像 1 Sony Walkman A-45 Battery Replacement: 手順 4、 2の画像 2
    • Remove the two bottom screws holding the chassis using a Phillips #00 screwdriver.
  5. Sony Walkman A-45 Battery Replacement: 手順 5、 3の画像 1 Sony Walkman A-45 Battery Replacement: 手順 5、 3の画像 2 Sony Walkman A-45 Battery Replacement: 手順 5、 3の画像 3
    • Flip the walkman on its screen.
    • Insert a Jimmy into the thin gap between the side panel and shell, along the edge of the panel.
    • Slowly pry up the back cover to release it from its adhesive.
    • If you have difficulty keeping the gap up, insert opening picks to prop it open.
  6. Sony Walkman A-45 Battery Replacement: 手順 6、 3の画像 1 Sony Walkman A-45 Battery Replacement: 手順 6、 3の画像 2 Sony Walkman A-45 Battery Replacement: 手順 6、 3の画像 3
    • Remove the five screws holding down the battery and NFC Module using a Phillips #00 screwdriver.
    • Detach the ribbon cable connecting the NFC Module by pulling outward.
    • Don't pull too hard or else the ribbon cable will rip.
  7. Sony Walkman A-45 Battery Replacement, Remove the Battery: 手順 7、 3の画像 1 Sony Walkman A-45 Battery Replacement, Remove the Battery: 手順 7、 3の画像 2 Sony Walkman A-45 Battery Replacement, Remove the Battery: 手順 7、 3の画像 3
    • Lift up the metal chassis carefully.
    • There will be a block piece which holds the wires. Pull it up carefully and it should come off.
  8. Sony Walkman A-45 Battery Replacement: 手順 8、 3の画像 1 Sony Walkman A-45 Battery Replacement: 手順 8、 3の画像 2 Sony Walkman A-45 Battery Replacement: 手順 8、 3の画像 3
    • Heat a soldering iron to 420 degrees Celsius.
    • Heat up the old solder in the Walkman and remove the wire from its terminal.
    • This process will take time to remove the wires.
  9. Sony Walkman A-45 Battery Replacement: 手順 9、 1の画像 1
    • Loosen the battery adhesive by using isopropyl alcohol.
    • Use Isopropyl Alcohol 90% or greater.
    • Pry out the battery using plastic cards.
    • Make sure to NOT bend the battery, Take your time during this process.
    • Remove the battery.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Edwin Ruiz
メンバー登録日: 10/24/24
223 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 3-86, Harris Fall 2024 CSU Los Angeles, Team 3-86, Harris Fall 2024人のメンバー
CSULA-HARRIS-F24S3G86
2 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 146
今までの合計 1,485
