はじめに
If your Sony WH-CH700N headphones have pads that are worn or need to be replaced, use this guide to replace them.
When the cover becomes brittle and tears off of your WH-CH700N headphones, the pads need to be replaced as the memory foam is left exposed. Here's how to replace the covers and extend the life of your headphones!
Before beginning, make sure to power off your headphones completely and disconnect from any external power source.
必要な工具と部品
この手順で使用する道具:Microfiber Cleaning Cloths$3.99
Gently wipe the exposed surface with an alcohol swab or microfiber cloth.
3 の人々がこのガイドを完成させました。
