メインコンテンツにスキップ
Sony WH-1000XM4 Motherboard Replacement
必要な工具と部品
  1. Sony WH-1000XM4 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Motherboard Replacement: 手順 2、 1の画像 1
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame. (The right ear cup is pictured, but the process is identical for the left ear cup.)
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • Repeat around the perimeter of the ear pad until it is loose.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the left ear pad. (The right ear cup is pictured, but the process is identical for the left ear cup.)
  4. Sony WH-1000XM4 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the foam liner from the left ear cup's speaker. (The right ear cup is pictured, but the process is identical for the left ear cup.)
  5. Sony WH-1000XM4 Motherboard Replacement: 手順 5、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover. (The right ear cup is pictured, but the process is identical for the left ear cup.)
  6. Sony WH-1000XM4 Motherboard Replacement: 手順 6、 1の画像 1
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the left ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with many cables.
  7. Sony WH-1000XM4 Motherboard Replacement: 手順 7、 1の画像 1
    • Unscrew the 4 screws in the corners of the motherboard to loosen it from the left ear cup assembly.
  8. Sony WH-1000XM4 Motherboard Replacement: 手順 8、 1の画像 1
    • Carefully remove the cable ribbon from the bottom of the motherboard.
  9. Sony WH-1000XM4 Motherboard Replacement: 手順 9、 1の画像 1
    • Carefully remove the multipin connector (multiple colorful wires) from the side of the motherboard.
  10. Sony WH-1000XM4 Motherboard Replacement: 手順 10、 1の画像 1
    • Carefully lift the motherboard out from the ear cup to access the other cable ribbons and connectors.
  11. Sony WH-1000XM4 Motherboard Replacement: 手順 11、 1の画像 1
    • Remove wires from the side or bottom of the motherboard that are attached by pin connectors.
  12. Sony WH-1000XM4 Motherboard Replacement: 手順 12、 1の画像 1
    • Desolder the remaining wires that are attached to the motherboard.
    • Repeat steps in reverse order to reassemble the headphones after seating the new motherboard.
    • Reference the Service Manual on the Sony WH-1000XM4 main page on the iFixit website to verify correct wire connections.
終わりに
作成者
3人の作成者と共同で作成されました。
Spencer Decker
メンバー登録日: 11/09/23
523 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-1, Harley Fall 2023 IUPUI, Team 2-1, Harley Fall 2023人のメンバー
IUPUI-HARLEY-F23S2G1
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 63
過去 30 日: 242
今までの合計 4,441
