メインコンテンツにスキップ
Sony Vaio VPCW21FX Keyboard Replacement
必要な工具と部品
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: 手順 1、 3の画像 1 Sony Vaio VPCW21FX Keyboard Replacement, Battery: 手順 1、 3の画像 2 Sony Vaio VPCW21FX Keyboard Replacement, Battery: 手順 1、 3の画像 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: 手順 2、 3の画像 1 Sony Vaio VPCW21FX Keyboard Replacement: 手順 2、 3の画像 2 Sony Vaio VPCW21FX Keyboard Replacement: 手順 2、 3の画像 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: 手順 3、 3の画像 1 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: 手順 3、 3の画像 2 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: 手順 3、 3の画像 3
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: 手順 4、 3の画像 1 Sony Vaio VPCW21FX Keyboard Replacement: 手順 4、 3の画像 2 Sony Vaio VPCW21FX Keyboard Replacement: 手順 4、 3の画像 3
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: 手順 5、 2の画像 1 Sony Vaio VPCW21FX Keyboard Replacement: 手順 5、 2の画像 2
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: 手順 6、 3の画像 1 Sony Vaio VPCW21FX Keyboard Replacement: 手順 6、 3の画像 2 Sony Vaio VPCW21FX Keyboard Replacement: 手順 6、 3の画像 3
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Nicholas Corcoran
メンバー登録日: 03/08/17
401 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 UMass Dartmouth, Team S2-G5, Isaacson Spring 2017人のメンバー
UMASSD-ISAACSON-S17S2G5
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 2,219
