はじめに
This easy to follow replacement guide is helpful if your fan is making a funny noise or overheating.
必要な工具と部品
Place your device upside down with the bottom panel facing upwards.
Orient the device so the battery is away from you as shown
Place the laptop upside down with the bottom panel facing upwards.
Locate the screw that holds the small panel covering your laptop's Ram. This panel should be in the dead center of your laptop.
Unscrew the screw and remove the panel.
ある他の人がこのガイドを完成しました。
