メインコンテンツにスキップ
Sony Vaio VPCCW17FX Speakers Replacement
必要な工具と部品
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: 手順 2、 1の画像 1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: 手順 3、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 3、 2の画像 2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: 手順 4、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 4、 2の画像 2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: 手順 5、 1の画像 1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: 手順 6、 1の画像 1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: 手順 7、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 7、 2の画像 2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: 手順 8、 2の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 8、 2の画像 2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: 手順 9、 3の画像 1 Sony Vaio VPCCW17FX Speakers Replacement: 手順 9、 3の画像 2 Sony Vaio VPCCW17FX Speakers Replacement: 手順 9、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
終わりに
作成者
6人の作成者と共同で作成されました。
Brianna Rukes
メンバー登録日: 03/21/17
101 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G5
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 548
