メインコンテンツにスキップ
Sony Vaio VPCCB290X LCD Screen Replacement
必要な工具と部品
  1. Sony Vaio VPCCB290X LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • First make sure the laptop is off and closed.
  2. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 2、 1の画像 1
    • Unlock the battery and push the release lever to remove the battery from the laptop.
  3. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 3、 2の画像 1 Sony Vaio VPCCB290X LCD Screen Replacement: 手順 3、 2の画像 2
    • Remove the screws marked in red to remove the hard drive cover and the screws marked in blue to loosen the hard drive. Then gently slide the hard drive out.
  4. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove all the screws that hold the plastic bottom on. There are some more screws that cant be seen in the photo.
  5. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 5、 1の画像 1
    • Gently pry up the plastic bottom and if it feels like it is resisting check the surrounding areas for more screws.
  6. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 6、 1の画像 1
    • Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. from here on out it is recommended that you wear a anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up
  7. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 7、 1の画像 1
    • Use a common or lat head screw driver to gently untangle the wires from their paths.
  8. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 8、 2の画像 1 Sony Vaio VPCCB290X LCD Screen Replacement: 手順 8、 2の画像 2
    • You will need to unscrew this small circuit board and fold it up to get the wires out from under it.
  9. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 9、 1の画像 1
    • Disconnect the screen from the motherboard.
  10. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 10、 1の画像 1
    • They are two hinges that hold the screen on. Make sure to pay attention to where the screws come from in order to put them back and to make installation easier.
  11. Sony Vaio VPCCB290X LCD Screen Replacement: 手順 11、 1の画像 1
    • By folding up the hinges the screen will simply slide away from the body of the computer and you can then put the new screen into place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Eric Martinez
メンバー登録日: 02/14/17
637 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G5
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 761
