メインコンテンツにスキップ
Sony Vaio VGN-Z48GD SSDs Replacement
必要な工具と部品
  1. Sony Vaio VGN-Z48GD SSDs Replacement, SSDs: 手順 1、 1の画像 1
    • Power off your laptop before starting.
    • Disconnect all external cables from the device.
  2. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 2、 1の画像 1
    • Flip the device over so that the battery is facing away from you.
    • Unlock the battery by using your finger to push the "Lock" latch to the right.
    • You will hear a soft click when the latch has been disengaged.
  3. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 3、 1の画像 1
    • Place your finger on the "Release" latch.
    • Slide the latch to the right and hold it.
    • Use your other hand to lift the battery from the groove.
    • Remove the battery.
  4. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 4、 1の画像 1
    • Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
    • Remove the RAM cover.
    • There is no need to remove the RAMs as they won't get in the way.
  5. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 5、 2の画像 1 Sony Vaio VGN-Z48GD SSDs Replacement: 手順 5、 2の画像 2
    • Remove the following eleven screws:
    • Five 13 mm Phillips #000 screws
    • Six 5 mm Phillips #000 screws
  6. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 6、 1の画像 1
    • Flip the device and open the lid so that the keyboard is facing upwards.
    • Use an opening tool to lift the keyboard assembly slightly.
    • Make sure you don't lift the keyboard assembly too much as there is a ribbon cable in between.
  7. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 7、 1の画像 1
    • Flip the keyboard assembly towards you.
  8. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 8、 1の画像 1
    • Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
    • Remove the keyboard assembly.
  9. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 9、 1の画像 1
    • Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
  10. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 10、 2の画像 1 Sony Vaio VGN-Z48GD SSDs Replacement: 手順 10、 2の画像 2
    • Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver.
    • Remove the SSD bracket.
  11. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 11、 1の画像 1
    • Flip the SSD bracket.
    • Use your hand to disconnect the uSATA connector on the right.
  12. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 12、 1の画像 1
    • Use your hand to disconnect the uSATA connector on the left.
    • Remove the uSATA ribbon cable.
  13. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 13、 1の画像 1
    • Remove two 2 mm Phillips #00 screws.
  14. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 14、 1の画像 1
  15. Sony Vaio VGN-Z48GD SSDs Replacement: 手順 15、 1の画像 1
    • Take out the SSDs from the bracket.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Vincent L
メンバー登録日: 01/10/19
265 ポイント
1ガイドが承認済み
チーム
York University, Team S3-G51, Melo-Thaiss Fall 2020 York University, Team S3-G51, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S3G51
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 33
今までの合計 834
