メインコンテンツにスキップ
Sony Vaio VGN-S260 Upper Casing Replacement
必要な工具と部品
  1. Sony Vaio VGN-S260 Upper Casing Replacement, Battery: 手順 1、 3の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement, Battery: 手順 1、 3の画像 2 Sony Vaio VGN-S260 Upper Casing Replacement, Battery: 手順 1、 3の画像 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 2、 2の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 2、 2の画像 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Upper Casing Replacement, Keyboard: 手順 3、 2の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement, Keyboard: 手順 3、 2の画像 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 4、 1の画像 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 5、 2の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 5、 2の画像 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 6、 2の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 6、 2の画像 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Upper Casing Replacement, Upper Casing: 手順 7、 1の画像 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 8、 3の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 8、 3の画像 2 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 8、 3の画像 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 9、 1の画像 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 10、 3の画像 1 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 10、 3の画像 2 Sony Vaio VGN-S260 Upper Casing Replacement: 手順 10、 3の画像 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Upper Casing Replacement: 手順 11、 1の画像 1
    • Remove the upper casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jeffrey Bryan
メンバー登録日: 04/20/10
570 ポイント
11のガイドは作成済み
チーム
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S16G4
4 メンバー
30のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 4,785
