メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
How to take out the Optical Drive from the Sony Vaio VGN-S260 laptop
パーツ
パーツは指定されていません。
  1. Flip the laptop over so the Vaio logo is facing down. Locate the battery at the top and Find the release and unlock slides on the battery. Slide the unlock tab to the unlock position.
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. With the tabs still in the unlock position, slide the battery away from the main case. With the tabs still in the unlock position, slide the battery away from the main case.
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Flip the computer over so the Vaio logo is facedown. Unscrew the 2 screws next to the battery.
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Flip the computer over again so the Vaio logo is face up.
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Press down on the outer gray shell around the keyboard. Use the spudger to gently lift keyboard.
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Lift up lever underneath the ribbon to detach the keyboard. Lift up lever underneath the ribbon to detach the keyboard.
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Remove memory/wireless compartment cover.
    • Remove memory/wireless compartment cover.
  8. Flip so the Vaio Logo is face down. Locate and remove a total of 8 screws on the bottom. Locate and remove a total of 8 screws on the bottom.
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Find and remove 5 screws (they all have arrows next to them) from cover.
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Flip the laptop over so the Vaio logo is face up. Use the spudger to pop up the upper casing. Do not lift too much as the upper casing is attached to wires underneath.
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Remove the upper casing.
    • Remove the upper casing.
  12. Remove the screw holding the optical drive casing to the logic board.
    • Remove the screw holding the optical drive casing to the logic board.
  13. Locate ribbon connecting optical drive case to logic board.
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Remove the four screws holding the optical drive to the logic board.
    • Remove the four screws holding the optical drive to the logic board.
  15. Locate brown locking tab above optical drive. Lift up on brown locking tab until ribbon is loose.
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
終わりに
ある他の人がこのガイドを完成しました。
Jeffrey Bryan
メンバー登録日: 2010年04月20日
552 ポイント
11のガイドは作成済み
チーム
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S16G4
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 22
今までの合計 4,399
