メインコンテンツにスキップ
Sony Vaio VGN-FS640 RAM Replacement
必要な工具と部品
  1. Sony Vaio VGN-FS640 RAM Replacement, Battery: 手順 1、 1の画像 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Replacement: 手順 2、 1の画像 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Replacement: 手順 3、 2の画像 1 Sony Vaio VGN-FS640 RAM Replacement: 手順 3、 2の画像 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: 手順 4、 2の画像 1 Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: 手順 4、 2の画像 2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Replacement: 手順 5、 3の画像 1 Sony Vaio VGN-FS640 RAM Replacement: 手順 5、 3の画像 2 Sony Vaio VGN-FS640 RAM Replacement: 手順 5、 3の画像 3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
  6. Sony Vaio VGN-FS640 RAM Replacement, RAM: 手順 6、 3の画像 1 Sony Vaio VGN-FS640 RAM Replacement, RAM: 手順 6、 3の画像 2 Sony Vaio VGN-FS640 RAM Replacement, RAM: 手順 6、 3の画像 3
    • To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
    • When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
    • Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
  7. Sony Vaio VGN-FS640 RAM Replacement: 手順 7、 1の画像 1
    • To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
    • Insert the gold leads of the RAM into the connection at the same angle the original chip was raised at after the tabs were released.
    • There is a raised tab on the connection that mates with a slit in the RAM to ensure you do not put the chip in upside down.
  8. Sony Vaio VGN-FS640 RAM Replacement: 手順 8、 1の画像 1
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Michael Maravick
メンバー登録日: 04/15/10
75 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S24G32
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 11
今までの合計 10,376
