メインコンテンツにスキップ
Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement
必要な工具と部品
  1. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement, Screen: 手順 1、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement, Screen: 手順 1、 2の画像 2
    • Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
    • Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
    • The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
    • You can find the tab looking for a solid fill within the grill. The tab is solid within the slits.
  2. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 2、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 2、 2の画像 2
  3. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 3、 3の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 3、 3の画像 2 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 3、 3の画像 3
    • Remove the two 5mm screws on the back of the device using a JIS 0 screwdriver.
  4. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 4、 3の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 4、 3の画像 2 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 4、 3の画像 3
    • Face the screen of the device upwards.
    • Gently un-clip the screen around the four sides of the body with the plastic opening tool.
    • Use an up-down motion.
    • It would be easier to do this if the device is fully rested flat by pushing the device down. It should rest on the stand.
  5. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 5、 3の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 5、 3の画像 2 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 5、 3の画像 3
    • Lift the screen gently from the top of the device.
    • Make sure to lift the screen from the same side the screws were removed.
  6. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 6、 1の画像 1
    • Slowly and gently lay the screen on its face.
    • It's important that the cables are not damaged while doing this process. Ensure as you lay the screen on its face any cables are carefully moved insuring no stress is applied on the cables.
  7. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement, Fan: 手順 7、 1の画像 1
    • Remove four 9mm screws from the fan attachment located on the motherboard with a Phillips #1 screwdriver.
  8. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 8、 1の画像 1
    • Remove two 6mm screws located on both sides of the fan component using a Phillips #1 screwdriver.
  9. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 9、 1の画像 1
    • Un-click the cables attached to the face of the motherboard.
    • These cables are secured tight in their place so remove them with a firm grip.
  10. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 10、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 10、 2の画像 2
    • Firmly lift the fan from the surface.
    • The fan is held tight in its place so lift it with slightly more force.
  11. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement, Speaker Assembly: 手順 11、 1の画像 1
    • Use a JIS 00 screwdriver to remove a 5mm screw from the wireless receiver.
    • The wireless receiver is a chip located in the area between the motherboard, fan, and one of the speakers.
  12. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 12、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 12、 2の画像 2
    • Gently detach the wireless receiver and place it somewhere it does not obstruct the speaker assembly.
  13. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 13、 1の画像 1
    • Remove a total of four 8mm screws with the Phillips #2 screwdriver from the speaker located below the motherboard.
  14. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 14、 3の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 14、 3の画像 2 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 14、 3の画像 3
    • Detach the cables that connect from the speaker to the motherboard.
    • The cables attached to the motherboard are held firmly in place so pull them with slightly more force to release them.
  15. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 15、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 15、 2の画像 2
    • Slowly lift the speaker from its base.
  16. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 16、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 16、 2の画像 2
    • Remove four 8mm screws from the speaker below the battery with a Phillips #2 screwdriver.
    • One of the four screws is located under a foam pad on one of the corners of the speaker. Lift the foam pad to remove the screw.
  17. Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 17、 2の画像 1 Sony Vaio Tap 21 SVT212A11L Speaker Assembly Replacement: 手順 17、 2の画像 2
    • Carefully lift the speaker from its base.
    • To fully remove the speaker assembly, remove the red and black intertwined cables that connect both speakers.
終わりに
作成者
1人の作成者と共同作成されました。
Mauricio Retana
メンバー登録日: 10/02/17
763 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S4-G4, Livingston Fall 2017 Cal Poly, Team S4-G4, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S4G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 436
