はじめに
Use this guide to replace the Bluetooth receiver on a Sony Vaio Tap 21 all -in-one desktop. This replacement is an easy repair that will fix your device's Bluetooth capabilities. You will notice the Bluetooth receiver needs replacing when the Bluetooth connection is not working or you receive a message on your screen indicating the Bluetooth capabilities are not working.
必要な工具と部品
Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
ある他の人がこのガイドを完成しました。
コメント 1 件
Just replaced my old WIFI/BT card in my VAIO T21, now 10 years old with this WiFi 6E Wireless Card, https://amazon.com/dp/B09P1B55JQ?psc=1&r.... Combined with adding a new 1TB SSD for my data drive (C: is already an SSD), my SVT21 is better than new. If only I could find a guide to upgrade the Core I5 processor with an I7.
Thanks, Mauricio, for the guide.
