Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Attach the suction cup to the top right area of the screen.
Pull to separate the screen from the rest of the device.
Be aware of the front camera cable that is still connected to the rest of the device.
Detach the display ribbon cable.
Unplug the battery connector located beside the fan.
Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
Gently tug either side until it releases, then pull out the other end.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
