メインコンテンツにスキップ
Sony Vaio Tap 11 Solid State Disk Replacement
必要な工具と部品
  1. Sony Vaio Tap 11 Solid State Disk Replacement, Screen Assembly: 手順 1、 1の画像 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Solid State Disk Replacement: 手順 2、 1の画像 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Solid State Disk Replacement: 手順 3、 2の画像 1 Sony Vaio Tap 11 Solid State Disk Replacement: 手順 3、 2の画像 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
    #1:
    I found pulling with two suckers started to bend the screen as the little clips holding the screen wouldn't release. So instead of risking damage I started to work my way around the edges of the screen by slowly pulling with the sucker and at same time  using the trusty old a spudger tool (Spudger) to gently pry open.
    #2:
    Be care sliding out the ribbon cable connector that goes to the screen. Its also tricky to slide back in after so you might need to peel the ribbon from the back plate to give some more wiggle room. I did.
    GB_Saints_Fan - 返信
    Cracked the screen following the instructions. Too bad I didn’t read the user’s comment. Fortunately it can still be used as normal, though on a white screen the cracks are evident. Good luck doing this .
    Colin Lai - 返信
    The comment is very important.
    #1. Spudger tools should be used together with suction cup.
    #2. Yes. I have small hands and was wondering how anybody with more normal sized hands would be able to do it. I made it but it was a bit tricky.
    grazyna.kosno - 返信
  4. Sony Vaio Tap 11 Solid State Disk Replacement, Solid State Disk: 手順 4、 1の画像 1
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Solid State Disk Replacement: 手順 5、 1の画像 1
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Solid State Disk Replacement: 手順 6、 2の画像 1 Sony Vaio Tap 11 Solid State Disk Replacement: 手順 6、 2の画像 2
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alexander Bridges
メンバー登録日: 09/16/15
1,217 ポイント
7のガイドは作成済み
チーム
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S1G2
4 メンバー
20のガイドは作成済み
3 件のコメント
What kind of M2 Type? SSD is needed for replacement/upgrade?
Marius - 返信
OK, found the answer, it's mSATA, like the Samsung 840 EVO Series:
http://www.samsung.com/us/business/suppo...
Marius -
I did the same without pulling out the battery jack. As i tried to turn the tablet on it didn’t work. Even the fan stopped working. I inserted the power cable but no response .. nothing at all ! Please help!
ib_1990_ib - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 25
今までの合計 5,971
