はじめに
This guide will provide detailed information in regards to the internal speakers and how to replace them. This may be necessary if there is any issue with sound volume or quality from the device that isn't present when using headphones.
必要な工具と部品
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Attach the suction cup to the top right area of the screen.
Pull to separate the screen from the rest of the device.
Detach the display ribbon cable.
#1:
I found pulling with two suckers started to bend the screen as the little clips holding the screen wouldn't release. So instead of risking damage I started to work my way around the edges of the screen by slowly pulling with the sucker and at same time using the trusty old a spudger tool (Spudger) to gently pry open.
#2:
Be care sliding out the ribbon cable connector that goes to the screen. Its also tricky to slide back in after so you might need to peel the ribbon from the back plate to give some more wiggle room. I did.
The comment is very important.
#1. Spudger tools should be used together with suction cup.
#2. Yes. I have small hands and was wondering how anybody with more normal sized hands would be able to do it. I made it but it was a bit tricky.
Remove the four 3 mm Phillips #000 screws from the upper and lower ends of each speaker module.
ある他の人がこのガイドを完成しました。
