メインコンテンツにスキップ
Sony Vaio SVT151A11L USB Port Board Replacement
必要な工具と部品
  1. Sony Vaio SVT151A11L USB Port Board Replacement, Battery: 手順 1、 2の画像 1 Sony Vaio SVT151A11L USB Port Board Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L USB Port Board Replacement: 手順 2、 3の画像 1 Sony Vaio SVT151A11L USB Port Board Replacement: 手順 2、 3の画像 2 Sony Vaio SVT151A11L USB Port Board Replacement: 手順 2、 3の画像 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: 手順 3、 3の画像 1 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: 手順 3、 3の画像 2 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: 手順 3、 3の画像 3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L USB Port Board Replacement: 手順 4、 3の画像 1 Sony Vaio SVT151A11L USB Port Board Replacement: 手順 4、 3の画像 2 Sony Vaio SVT151A11L USB Port Board Replacement: 手順 4、 3の画像 3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: 手順 5、 2の画像 1 Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: 手順 5、 2の画像 2
    • Use a JIS #0 screwdriver to unscrew the two 4mm screws from the board.
  6. Sony Vaio SVT151A11L USB Port Board Replacement: 手順 6、 3の画像 1 Sony Vaio SVT151A11L USB Port Board Replacement: 手順 6、 3の画像 2 Sony Vaio SVT151A11L USB Port Board Replacement: 手順 6、 3の画像 3
    • Lift board and peel the ribbon cable from the computer.
    • Lift and pull the end of the ribbon cable to remove it from the slot.
終わりに
作成者
1人の作成者と共同作成されました。
Nathan McGarvey
メンバー登録日: 10/20/17
481 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G6, Julie Fall 2017 UMass Dartmouth, Team S4-G6, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G6
2 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,052
