はじめに
A multimedia card is a memory card that is used to store data on your device and is attached to the reader inside the laptop.
必要な工具と部品
Flip the laptop over so that the battery on the underside of the device is revealed.
Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
Unscrew the three 4mm screws using a JIS #0 screwdriver.
Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
Grab and lift the edge of the panel to pull it free from the rest of the computer.
もう少しです!
終わりに
