メインコンテンツにスキップ
Sony Vaio SVT131A11L Battery Replacement
必要な工具と部品
  1. Sony Vaio SVT131A11L  Battery Replacement, Battery: 手順 1、 3の画像 1 Sony Vaio SVT131A11L  Battery Replacement, Battery: 手順 1、 3の画像 2 Sony Vaio SVT131A11L  Battery Replacement, Battery: 手順 1、 3の画像 3
    • Carefully grab the edges of the laptop and flip it over to reveal the back panel.
    • The battery is located on the lower half of the back panel, and contains three 10mm flat-head screws.
    • Unscrew the three 10mm flat-head screws using a flat-head screw driver.
    • Lift the battery from the lip closest to the middle screw to remove the battery entirely.
終わりに
作成者
3人の作成者と共同で作成されました。
Benjamin
メンバー登録日: 10/18/17
651 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G5, Julie Fall 2017 UMass Dartmouth, Team S4-G5, Julie Fall 2017人のメンバー
UMASSD-JULIE-F17S4G5
3 メンバー
10のガイドは作成済み
7 件のコメント
Hello,
Where can I buy a replacement battery? The link for amazon does not work.
kristina1152003 - 返信
I bought it from amazon, look for bps30 and youll find it.
rg.paulinha -
It says battery not detected, what can I do?
rg.paulinha - 返信
My 3rd party battery is not recognized as well. Any tips for me?
Shivakumar Sundaram - 返信
Hi, I need a body pannel for Sony laptop model number:SVT131A11L. Already used piece also I will take if it is good. Please help me.
Sriram Gokani - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 35
今までの合計 3,399
