はじめに
This guide shows how to replace a hard drive in a Sony Vaio SVS151190X laptop. A hard drive replacement is needed when the device storage is full or nearly full. Your device may also have a faulty hard drive, due to old age or damage of some sort. If possible, clear your hard drive of junk files to free up space before purchasing or installing a new hard drive. You may also want to consider purchasing an external storage device before replacing your hard drive.
必要な工具と部品
Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
Slide off the back cover.
ある他の人がこのガイドを完成しました。
