必要な工具と部品
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
