はじめに
This guide helps users to remove the back panel, which is required to access the other pieces of the laptop and is the first step to any part replacement.
必要な工具と部品
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
もう少しです!
終わりに
