メインコンテンツにスキップ
Sony Vaio SVE171C11L Speaker Replacement
必要な工具と部品
  1. Sony Vaio SVE171C11L Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Speaker Replacement: 手順 2、 1の画像 1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Speaker Replacement: 手順 3、 1の画像 1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Speaker Replacement: 手順 4、 1の画像 1
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Speaker Replacement, Hard Drive: 手順 5、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Speaker Replacement: 手順 6、 2の画像 1 Sony Vaio SVE171C11L Speaker Replacement: 手順 6、 2の画像 2
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Speaker Replacement: 手順 7、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Speaker Replacement: 手順 8、 1の画像 1
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
  9. Sony Vaio SVE171C11L Speaker Replacement, Speaker: 手順 9、 2の画像 1 Sony Vaio SVE171C11L Speaker Replacement, Speaker: 手順 9、 2の画像 2
    • Remove the eleven 3mm flathead screws that surround the back panel.
    • Remove the back cover.
  10. Sony Vaio SVE171C11L Speaker Replacement: 手順 10、 1の画像 1
    • On the left speaker, unplug the cable that is in the way so you can remove the left speaker safely.
  11. Sony Vaio SVE171C11L Speaker Replacement: 手順 11、 1の画像 1
    • Remove the single screw at the bottom of the speaker
  12. Sony Vaio SVE171C11L Speaker Replacement: 手順 12、 1の画像 1
    • Remove the 2 black scews that at the top of the speaker.
  13. Sony Vaio SVE171C11L Speaker Replacement: 手順 13、 2の画像 1 Sony Vaio SVE171C11L Speaker Replacement: 手順 13、 2の画像 2
    • Carefully remove the speaker. Keep watch no wiring is in the way.
    • Do this to both sides to remove the second speaker.
終わりに
作成者
3人の作成者と共同で作成されました。
Edward Briseno
メンバー登録日: 09/26/22
896 ポイント
6のガイドは作成済み
チーム
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022人のメンバー
CSULA-ADACHI-F22S6G3
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 129
