メインコンテンツにスキップ
Sony Vaio SVE171C11L Motherboard Replacement
必要な工具と部品
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: 手順 2、 2の画像 1 Sony Vaio SVE171C11L Motherboard Replacement: 手順 2、 2の画像 2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: 手順 3、 2の画像 1 Sony Vaio SVE171C11L Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: 手順 4、 1の画像 1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: 手順 5、 3の画像 1 Sony Vaio SVE171C11L Motherboard Replacement: 手順 5、 3の画像 2 Sony Vaio SVE171C11L Motherboard Replacement: 手順 5、 3の画像 3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
終わりに
作成者
7人の作成者と共同で作成されました。
Edward Briseno
メンバー登録日: 09/26/22
896 ポイント
6のガイドは作成済み
チーム
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022人のメンバー
CSULA-ADACHI-F22S6G3
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 26
今までの合計 367
