メインコンテンツにスキップ
はじめに
The motherboard is the component that controls the logic and computation of the laptop. This guide shows the steps to remove the motherboard for repair or replacement.
パーツ
パーツは指定されていません。
  1. Turn the laptop over so its underside is facing upwards and visible.
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Standing so that the barcode and warning labels are upright and legible,  push the left tab up and away from yourself.
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Standing so that the barcode and warning labels are upright and legible,  push the right tab up and away from yourself.
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Pull battery away from laptop.
    • Pull battery away from laptop.
  6. Android 修理キット
    A new screen or battery is one kit away.
    ショップを見る
    Android 修理キット
    ショップを見る
  7. Flip laptop over so the bottom is facing upwards.
    • Flip laptop over so the bottom is facing upwards.
  8. Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  9. Pop open the cover to the HDD. Pop open the cover to the HDD.
    • Pop open the cover to the HDD.
  10. Remove the  screws on the HDD with a Phillips #000 screwdriver.
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  11. Pull plastic tab away from the laptop. Lift HDD away from laptop.
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
  12. Flip the laptop over on its backside.
    • Flip the laptop over on its backside.
  13. Remove the screws holding the motherboard in place.
    • Remove the screws holding the motherboard in place.
  14. Pop the motherboard away from the frame. Pop the motherboard away from the frame.
    • Pop the motherboard away from the frame.
  15. Remove the ribbon cable from the motherboard.
    • Remove the ribbon cable from the motherboard.
  16. Remove motherboard from the laptop. Remove motherboard from the laptop.
    • Remove motherboard from the laptop.
まとめ
Alex Theg
メンバー登録日: 2018年10月15日
641 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018人のメンバー
UMASSD-VALLIERE-F18S9G9
4 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 29
今までの合計 252
