メインコンテンツにスキップ
Sony Vaio SVE15112FXS LCD Screen Replacement
必要な工具と部品
  1. Sony Vaio SVE15112FXS LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 2、 3の画像 1 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 2、 3の画像 2 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 2、 3の画像 3
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  3. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 3、 1の画像 1
    • Turn the computer back over and open the lid.
    • Remove the four rubber screw covers at each corner of the screen to expose the bezel screws
  4. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 4、 1の画像 1
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screen bezel screws in each corner.
  5. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 5、 2の画像 1 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 5、 2の画像 2
    • Insert a plastic opening tool between the bezel and laptop lid. Work it around the edge to loosen the bezel.
    • Lift the bezel outward to remove it and expose the screen.
    • Take care when using the spudger near the hinges to avoid breaking the bezel.
  6. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 6、 2の画像 1 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 6、 2の画像 2
    • Use a #0 Phillips screwdriver to remove the four 3.0 mm screen screws.
    • Cover the keyboard with a cloth or towel to protect the screen and keep any broken glass out of the keyboard.
  7. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 7、 3の画像 1 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 7、 3の画像 2 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 7、 3の画像 3
    • Pull the screen toward you and away from the lid until a silver cable behind the screen is visible.
    • Remove the silver cable from the back of the screen. It is glued at the top and the bottom.
    • Do not pull the cable loose from the lid, only remove it from the back of the screen.
  8. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 8、 3の画像 1 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 8、 3の画像 2 Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 8、 3の画像 3
    • Lift the barcode label on the back of the screen upward to loosen the screen cable connector.
    • Once the connector is visible, remove it from the pins on the back of the screen.
  9. Sony Vaio SVE15112FXS LCD Screen Replacement: 手順 9、 1の画像 1
    • Lift the screen toward you to remove it completely from the lid.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ashley Bierman
メンバー登録日: 09/06/18
1,223 ポイント
5のガイドは作成済み
チーム
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018人のメンバー
OSU-WHITNEY-F18S1G1
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 877
