はじめに
If your laptop display is damaged or does not work at all, you can use this guide to replace the LCD Screen. This process is simple, and only requires a #0 Phillips screwdriver, plastic opening tool, and magnetic project mat to keep track of the screws for each step. Be sure to handle the LCD Screen and all wires with care, as they are delicate parts.
必要な工具と部品
Turn the laptop over so that it is positioned top down with the model number facing you.
ある他の人がこのガイドを完成しました。
