メインコンテンツにスキップ
Sony Vaio SVE111B11L Motherboard Replacement
必要な工具と部品
  1. Sony Vaio SVE111B11L Motherboard Replacement, Battery: 手順 1、 2の画像 1 Sony Vaio SVE111B11L Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Motherboard Replacement: 手順 2、 1の画像 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Motherboard Replacement: 手順 3、 1の画像 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Motherboard Replacement, Keyboard Assembly: 手順 4、 1の画像 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Motherboard Replacement: 手順 6、 1の画像 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Motherboard Replacement: 手順 7、 3の画像 1 Sony Vaio SVE111B11L Motherboard Replacement: 手順 7、 3の画像 2 Sony Vaio SVE111B11L Motherboard Replacement: 手順 7、 3の画像 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L Motherboard Replacement, Fan: 手順 8、 1の画像 1
    • Locate the fan and heat-sink.
  9. Sony Vaio SVE111B11L Motherboard Replacement: 手順 9、 1の画像 1
    • Locate the wires and connectors, and gently unplug them.
  10. Sony Vaio SVE111B11L Motherboard Replacement: 手順 10、 1の画像 1
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Sony Vaio SVE111B11L Motherboard Replacement: 手順 11、 1の画像 1
    • Gently lift the fan assembly up and out.
  12. Sony Vaio SVE111B11L Motherboard Replacement, Motherboard: 手順 12、 1の画像 1
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  13. Sony Vaio SVE111B11L Motherboard Replacement: 手順 13、 1の画像 1
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  14. Sony Vaio SVE111B11L Motherboard Replacement: 手順 14、 3の画像 1 Sony Vaio SVE111B11L Motherboard Replacement: 手順 14、 3の画像 2 Sony Vaio SVE111B11L Motherboard Replacement: 手順 14、 3の画像 3
    • Locate the wires and connectors and remove them from the motherboard.
  15. Sony Vaio SVE111B11L Motherboard Replacement: 手順 15、 2の画像 1 Sony Vaio SVE111B11L Motherboard Replacement: 手順 15、 2の画像 2
    • Lift the mother board out and safely put it to the side.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
John Noll
メンバー登録日: 09/29/16
819 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Crane Fall 2016 Eastern Washington University, Team 1-5, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G5
4 メンバー
10のガイドは作成済み
コメント 1 件
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
onyebuchiadieze - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,919
