メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
パーツ
パーツは指定されていません。
  1. Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector. Locate the battery on the bottom of the computer.
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Locate the two latches with the words “lock” and “release” on them.
    • Locate the two latches with the words “lock” and “release” on them.
  3. Push the latches towards each other and lift the battery to remove it.
    • Push the latches towards each other and lift the battery to remove it.
  4. Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Remove the 6.7 mm screw that holds the keyboard assembly in place.
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Be careful not to break the keyboard wire connection.
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches. Using an opening tool, gently pull out and slightly up on the connector clip. Gently lift the keyboard assembly up and out.
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
終わりに
2 の人々がこのガイドを完成させました。
John Noll
メンバー登録日: 2016年09月29日
777 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Crane Fall 2016 Eastern Washington University, Team 1-5, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 919
